4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Fuzzy screen after replacement?
Okay so here's my problem. I dropped my iPhone SE and the screen is now black with white lines on the side. I then proceeded to order 3 new replacement screens (Just incase one is faulty and one for spare) and when I tried the new screen in my SE it works but its fuzzy as if there is static or something similar. My question now is should I try buy an old iPhone 5s and use that screen as a replacement and put one of the aftermarket ones in that 5s and resell it if it works? Or is it possible for the logic board itself to be damaged? When I try the original screen it still turns on unlike the other guy that asked the same question here and ended up with two dead SEs.
Score 1
Add a comment
Chosen Solution
A 5S replacement screen with OEM/Original parts work well in the SE but aftermarket 5S screens are known to have issues. So depending on the quality level you ordered and from who you ordered it from, it may cause various issues such as what you are seeing.
Your logic is sound though, you could use an original 5S screen on the SE and put the replacement in the 5S. As long as your upfront about it with the folks that purchase it (i.e. the screen has been repaired/replaced).
Score 5
3 Comments:
Just as ifixit says, I am eternally greatful thank you. I will buy a 5s and use that screen and resell it as refurbished with an aftermarket screen.
by
About that eternal gratefulness of yours...maybe you can help me with a little problem I have... :>)
Kidding, glad I could help!
by
Is there a way to put a golden border around your answer? Jokes, thanks for the help.
by
Add a comment
Minho is correct with the possability of you having faulty screens (Watch where you order from). When installing the aftermarket screen make sure the connector is properly seated. Also make sure that you have disconnected the battery. After Installation is complete reconnect the battery and the screen should be clear. If not send back your faulty screen. I do not beleive its your logic board as you would be having other issues but logic boards can be damaged fairly easily if you are not careful.
1 Comment:
Well i just hooked my perfectly fine screen up to someone elses phone and immediatly it had static issues from boot up,a bunch of horizontal wavy lines.After I put it back on my phone the screen does the same thing,as if that phone had some sort of damage that causes this permanant damage to the display(s) so im going to ahead and guess its your phone.And this came about from someone touching your phone that had no idea how important it is to be careful.As this was the case in which my screen just got ruined.It was a 12 yr old kid that had no clue what he was doing lol
The odds of 3 screens not being good as opposed to it being your phone are not very high.You probably have logicboard damage and your phone just destroyed all 3 of them lcd’s.
by
Add a comment
Add your answer
Liam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 6,284
