How can replace battery? (pinout)
Hi friends.
I want to change my ultrabook battery with an after-market one. I already found few batteries with same voltage value but I have a problem. Normally most of the notebook batteries have 9 pinouts (3 ground , 3 V+ , 1 SMC+ , 1 SMC- and center pin) but somehow this notebook has 11 pinouts , you can see in below picture.
What I was wondering if is there a way to connect a battery with 9 pinouts into my ultrabook`s motherboard which has 11 pins ? Maybe there is a converter that I am not aware of ? Or I can simply align the pins by soldering some pin cables ?
https://i1.wp.com/www.techniumc.com/wp-c...
Score 1
Add a comment
1 Answer
Tf there are more grounds/ v+ ==> you can just make an adapter, but when I was disassembling my 12.5 I saw, that there were data pins, so your power controller possibly will not recognize your battery.....
Add a comment
Add your answer
Seçkin Güvenç will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 3,527
