Microsoft's third-generation Xbox game console, released November 22, 2013.
730 Questions View all
Xbox starts by itself and shuts off. Rapidly.
Hey there! My Xbox has been going strong for the past while, but a little while ago, it started shutting itself off at random times, and it got progressively worse, to the point where it would start itself up, and shut off randomly, and rapidly. I took it apart, and cleaned everything, and paid close attention to cleaning the Rf module, and it worked again. For a couple months anyway. Now it's back to doing it again. It's not overheating, it's not filthy inside, so what is it?Am I right, Is something wrong with the Rf module? I just need to know so I know what part I need to order to end this once and for all. It's really tedious, because I use it to watch YouTube when I'm trying to sleep, and without it, I'm at a loss! Thanks in advance!
Score 1
Add a comment
Most Helpful Answer
If you have or can get a hold of a wired controller try this:
Remove the front panel and RF board.
Used wire controller to turn on the console.
If the problem stops then you know your rf board is faulty.
Score 1
1 Comment:
You can also insert a disk to power on the console. Very good idea though.
by
Add a comment
I'd start by replacing the front panel (replacement part), it could well be a faulty power on/off touch sensor. If the problem still persists after that then move on to the RF Module board (replacement part) following this guide to for both jobs
Xbox One Front Panel Image
Product
$14.99
Xbox One RF Module Board Image
Product
$5.99
2 Comments:
I've started it up without the front panel on, and it's done the same thing too
by
change the RF board mate..
by
Add a comment
Hello I've had this same issue lately and I cleaned the RF module and nothing happened! so I replaced the heat sink and the fan and it worked perfectly fine and have had no problems since. These guides might help.
Xbox One Fan Replacement Xbox One Heat Sink Replacement
If you have any questions or concerns please comment below. Thank you
Xbox One Heat Sink Image
Guide
Difficulty:
Moderate
1 - 2 hours
Xbox One Fan Image
Guide
Difficulty:
Moderate
40 minutes - 1 hour
8 Comments:
I thought it was a fan problem too, but the disk tray also shoots out whatever do's is in there every now and again too
by
Oh that's really werid I have never heard of this happening have you checked all of the voltages on the board ?
by
Or have messed with anything not the cleaning it it sounds like the board is shorting out?. And have you tried different power supplies?
by
Did you fix it?
by
No, not yet. I'm going to see if I can get some money together and try to replace the Rf module, and see if that works
by
Show 3 more comments
Add a comment
Add your answer
Mark Whittaker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 8,259
