Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
23 Questions View all
How do I fix the loose samsung chromebook plus bottom panel
I bought a Samsung chromebook plus and it has a loose bottom panel to the right of the touch pad,this originally occured as I removed the laptop from tablet mode,how do I fix it?
Score 2
Add a comment
1 Answer
You will need a PHILIPS Size 0 screwdriver to remove the back panel. You will have to remove the 8 screws on the back (there are none under the plastic feet), then you will need a plastic card so you can stick it between the body and the cover, then slide the card around the sides to pop them out, after that you can just separate the hinge-side of the panel from the body with your hands. However, putting the cover back on is much harder. iFixit Guide: How to disable the touchscreen on a Samsung Chromebook Plus
Skip steps 4, 5, and 6.
Add a comment
Add your answer
Baker Wadamba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,187
