Quit working wont turn on
Conair bonnet hair dryer only 3 months old quit working
Score 1
1 Comment
My Conair hair dryer stopped working, should I send it back to the company
by
Add a comment
Chosen Solution
Suzy Cory, Try another known working outlet. If no go, more then likely has a one year warranty on hair dryer and you may want to consider contacting the manufacturer for repair/replacement/refund. If not you could disassemble the hair dryer and test/check all connections, cord/plug, switch, if fused check, with a DVOM to see if faulty. Below is a guide to disassemble various models that may help. If not wanting to work on the dryer yourself perhaps have a good local small electronics shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Hair Dryer
Score 2
2 Comments:
Looks like we were answering this at the same time.
by
mayer, yes, been a while since it had happen :-)
by
Add a comment
Most Helpful Answer
It is covered under warranty. First try returning it to place of purchase.
That failing, register it here, then request a warranty repair:
https://www.conair.com/co/101e94/product...
Score 2
Add a comment
If it experienced a reduction of airflow, you might have tripped the safety fuse on the heating element.
Add a comment
Add your answer
Suzy Cory will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 11,442
