Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2739 Questions View all
Mackie SRM450 trouble shoot amp section
Can anyone advise on best way to trouble the Mackie SRM450 amp section I have several with different faults, some dead, some just high frequencies from mid driver, scratch noise
would like some sort of flow chart or something, have schematics just want to know how to test and in what order
2 Comments
Low sound erorr & high out DCv to
by
amplifier srm450 low speaker good
Hi speaker no waking
Hi speaker amplifier good not signal waking SLR canectar ples help
by
Add a comment
Most Helpful Answer
@clayt0n this is a tall order since you are talking about multiple devices with multiple errors. Pick one device and deal with the failure. That way you do not get confused by trying to many things at once. Use the test points on your circuit board to find faults or perform adjustments. Something like this for "high frequencies from mid driver, scratch noise" for example:
there is a bit more in the SM Mackie SRM450
Score 1
Add a comment
This might be a year late, but you should start with units that power up, but have no high or low (or both) output. With the unit on it's face and unplugged, remove the amplifier module from the back, and set it across the normal position. Disconnect the four wire speaker plug from the amp board that leads into the cabinet so that you can test the high and low speakers. If you have an ohmmeter, you can use it to see if you read a low resistance (10 ohms or less) across each speaker coil. If you don't have an ohmmeter, you can use a pair of wires or test leads and a low current battery like a 9 volt cell to apply a voltage to the high and low speakers, while listening for a thump (low), or a click (high) from each driver. If your ohmmeter reads open, or if you don't hear a response from the battery voltage, then the speakers are probably open and will need to be replaced. Don't worry about meter or battery polarity, or connecting to the wrong wires, because you can't hurt anything with either of these tests.
If you get good readings or response, but still have no output from one or both drivers, then the problem is most likely in the amplifiers, and will be harder to diagnose and repair. Note that passing this basic test doesn't mean that the speakers are 100 percent healthy, it just means that you should hear something when they're connected to a working amplifier.
You may be able to swap parts from units with good drivers but bad amps into units with bad drivers and good amps and get something that works. This is fairly easy for the low driver which can be pulled from the front, but not so much for the high driver, which you can't reach without disassembling the whole cabinet.
I could add more on basic amp troubleshooting if anyone is still interested.
Hope this helps.
1 Comment:
I realise this was six months ago but I would definitely be interested in some basic amp troubleshooting if you would be up for sharing. I currently have a pair of Srm 450s that power up fine, the drivers work when removed but have no output
by
Add a comment
Hi maybe unrelated but I have Mackie c300z cabs they both failed .Are about 6 years old.thinking it was my amp I tried another on them and no wasn't the amp.stripped one down found the cones were solid no movement so had to rip cone out as I needed to rule out the amps.found the speaker coils jammed by the moved magnetics hence a write off so much for mackies speaker reputation as obviously is a build fault as they shouldn't move but they can not going to pay mackies exaubitent prices to fail again.
Add a comment
Add your answer
Clayton Fulmar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 48
All Time: 3,496
