Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
No service - hardware issue
Hi,
So the other day my iphone 6s has been displaying "No service", and therefore I can not make phone calls, text messages, and access the internet. I have tried all the known basic fixes, such as,
- Time and date issues.
- Switching the phone on and off.
- Removing the sim card.
- Putting the phone in and out of airplane.
- restoring the phone.
- I have even taken the the phone to an apple store, for a software restore.
- Network coverage, and the network coverage is fine.
Another thing that I tried was to swap sim cards over with my girlfriend. Her sim card did not work on my phone, but my sim card worked on her phone. Therefore I have concluded that this must be a hardware issue.
When I dial *#06# I get my IMEI no. displayed on screen, and it also shows up in the settings. Any ideas as to what the problem might be or where the problems might lie, and can it be fixed?
Cheers,
Matt
Score 4
5 Comments
Hello! Have you had any in luck in repairing/fixing ? I have the exact issue on my iPhone 6s
by
Hi Rem Iri,
Unfortunately I did not manage to fix this myself. I asked the company (where I purchased the phone) for a free replacement phone, saying that there must be a manufacturing problem. They replaced my phone free of charge.
I’m guessing you’ve tried the fixes that I have listed above?
I hope you can get yours sorted.
Cheers,
Matt
by
All the repair shops I went to says it’s a hardware problem. I have this issue for over a year now, but since I travel now alot I’m thinking of fixing it.
My only mistake was I didn’t ask for a replacement sooner (already past warranty period)
I think I’m going to have a proffesional fix it instead (good luck to me for the charge).
Thanks Matt, Happy Holidays.
by
Hi Rem Iri,
My phone developed this problem around 1.5 years after getting it through a contract. My one year warranty also had expired by this time. I had taken it to an Apple shop and they wrote me a report saying that there appears to be a hardware issue with the phone. I sent this report to “the company” to aid my case for a free replacement. “The company” also checked it over themselves and said yes to a free replacement even though it was out of warranty. Maybe you could try the same with the company you purchased it from.
Cheers, and happy holidays.
Matt
by
I’ll definitely try that out! Thanks again sir!
by
Add a comment
Chosen Solution
Your troubleshooting has been very good and you have eliminated quite a few things.
Has your phone been dropped, repaired or even opened out of curiosity just shortly before you had problems? Did it come in contact with water or high humidity?
My thinking is that one of the internal antenna connections may have come loose. The fact that your phone sees the IMEI generally rules out a baseband IC issue. If you're comfortable, you could open up your device and look for anything out of place such as disconnected connectors, red water indicators etc. However, tread carefully, disconnect the battery first (especially on the 6S) and don't force anything.
Score 3
3 Comments:
Hi Minho,
Thank you for taking the time to respond.
In answer to your question, the phone has not been in contact with water, high humidity, or been opened. Due to the slippery nature of the phone, I have dropped the phone on occasion. Externally, the phone looks in perfect condition, and so there doesn't seem to be anything visual on the outside.
If I were to open the phone for a closer inspection, would you be able to provide me with more guidance on where I can locate the internal antenna connections? Also, you have mentioned red water indicators, what are those?
Thank you for your help. Much appreciated.
Cheers,
Matt
by
You should comment on the answer rather than create a new answer. That way it keeps things in sync (over time, many more answers and comments may come) and it sends me a notification. I just caught this by chance.
I would look at this guide (iPhone 6s Cellular Antenna Replacement) and this part (iPhone 6s Cellular Antenna), this guide (iPhone 6s Wi-Fi Diversity Antenna Replacement) and this guide (iPhone 6s Lightning Connector Assembly Replacement)
by
Hi Minho,
Thanks for your help. I shall be having a go at this when I have some spare time.
Cheers,
Matt
by
Add a comment
Try this: Hold down the power and home buttons to turn of the phone, and keep them depressed until the phone restarts itself. Continue holding these buttons down until the phone then turns itself back off. Wait a few seconds, then depress them again until it starts up, then let go of the buttons. I've heard this has worked for some people.
I have also read about the "drop technique" where people put the phone in a case then drop it from about 6 or more inches onto a hard surface with the screen facing towards the ceiling. I wouldn't personally do this until I've tried everything else but many people have backed this technique.
Score 1
3 Comments:
Hi Justin,
Thank you for your response. I have tried the first part that you have mentioned with no such luck. Before trying the "drop technique" I think I will have a little gander inside first.
Cheers,
Matt
by
I did some research and found a forum and one guy said "I found that a little soft pad that looked like it has melted from its place. It supposed to stick to the antenna cable exactly below the ear speaker, and the lcd unit pushes this cable down, probably making electrical contact somewhere. After closing the phone it kept searching for a network for a day. But after a reset the carrier was back! This also seemed to be a common problem. So be sure to reset the phone!" I'm not sure on the effectiveness, but I thought I'd share.
Best regards,
Justin
by
Cheers Justin. I will look out for this when opening the phone. Appreciate it.
Matt
by
Add a comment
I fixed and solved 90% some of those iphones (around 100 iphone I worked)by replacing cellular cable which is located inside logic board.
1 Comment:
Could you tell me which cable . There are two at the backside ?
by
Add a comment
Hi my new iPhone keep saying no service then it works but it says no service again it usually works when I use it and says no service when I put it down I have tried all the methods from power on to power off to factory reset but still the same how do I fix this
Add a comment
Add your answer
Matthew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 78
All Time: 27,160
