Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
59 Questions View all
does not work, screen not working
copied from PLEASE HELP! Beeping and black screen when laptop turned on
I am having a slimier problem mine was dropped once and is has not worked since, so there is little hope. when ever you plug it in all of the lights come on but the screen does not, also the fan comes on, you are still able to turn it off by holding the power button for a few seconds but it does not beep. when you unplug it it will turn off. please help!
Score 1
Add a comment
1 Answer
Is there any blinking sequences? I had a Pavilion that the CPU went bad on. The laptop would start but the lights would flash in a certain order every few seconds. It could be possible for many things on the laptop ended up breaking. Hard drives for example can be very easily damaged by impact. It could also be the screen might just have been damaged and you need a new one. It's very hard to determine the problem unless I'd be looking at it myself or unless it's throwing some codes indicating something is bad.
Add a comment
Add your answer
Jake Bleck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 215
