7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Screen replaced now charge won't hold
I recently had my daughters iPad mini's screen replaced, when it was dropped off everything worked fine, minus the crack in the screen... after picking it up the charge would no longer hold, its showing as connected but the percentage does not increase... I brought it back and they told me the battery died and it's not related... is this possible? There was absolutely no battery issue previously.
Add a comment
1 Answer
Chosen Solution
Obviously, I don't have all the info but as a repair shop, I will say that it is indeed possible. Whether this is the case for you, I couldn't say.
An iPad mini is an older model at this point and if you never had the battery replaced it is logically much closer to the end of it's life than the beginning. Batteries degrade over time and we don't usually notice anything until it becomes painfully obvious. Also, depending on our usage and charging habits, you may not really notice a difference.
So what I would do right now is download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition. It will tell you what the percentage of the design capacity is left in the battery. Anything less that 75% will mean the battery is not holding a charge for very long and anything less than 60% means the battery is pretty much done.
Now, as an aside, whenever someone brings an iPad in for repair, I always test the battery first. iPads are secured with adhesive and are a major pita so I wouldn't want to have the customer (or me) open it again just to change a battery. Kinda like when the city re-paves your street and later in the year, some utility tears it up to change wires or plumbing or something...dumb and avoidable.
Another point to consider is that changing a cracked digitizer really doesn't require the tech to play around with either the battery or logic board so unless they had a serious brain cramp, it's hard to see how the two are related.
Score 4
1 Comment:
I have a mini that came with iOS 6, and the battery is still quite nice. I have a good habit of charging it at 75%, and I believe you should try this as well.
by
Add a comment
Add your answer
Amanda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 106
