Repair and troubleshooting information for the Suzuki FA50 Moped.
75 Questions View all
After riding my moped, it wont stay idling
I can get my moped to run and idle but after driving it for a while and then coming to a stop it doesn't always stay idling, I think that either I have to leave the choke on a little but I am not sure. It seems to only happen after I return the throttle to the complete off position.
Add a comment
1 Answer
Chosen Solution
@madmax9 I would try to clean and adjust the carb. You want to start with the air/fuel mixture screw first. Also check your float height and make sure that the level is right and that the needle valve is not stuck. I suggest to download the service manual for your moped from here (bottom of the page). Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Max Trozenski will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 15
All Time: 714
