Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
How to dismantle MBP and clean the keyboard backlight after spill?
I spilled some coffee on my two weeks old MBP. It has dried and everything works, the only problem is that the keyboard backlight is strong just in the center of the keyboard (under TYUGHBN keys) and fades toward sides.
I think that it's caused by the coffee preventing the light from coming through the keyboard. Here is a similar problem described on an older model - Keyboard backlight only glows in center
It seems to be necessary to remove and clean the layers of plastic placed between the keyboard and the backlight diods. I've purchased some tools from ifixit and will try to do it myself. Any hints and suggestions will be very much appreciated.
Score 1
Add a comment
Chosen Solution
Here's the guide you need to follow: MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement
Score 2
4 Comments:
Thank you! Any recommendations regarding the cleaning part?
by
It's according to what was in the coffee. I've cleaned parts using distilled water and it works fine if given the time to dry correctly.
by
There was only a little bit of milk in the coffee.
by
Look for the liquid submersion indicators that may have turned red. They will tell you if an area has gotten wet and needs cleaning.
by
Add a comment
Is the same guide relevant for a late 2011 MBP?
Add a comment
Add your answer
jakub will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 12,563
