Released May 2012, identified by model number J2011-03-US.
45 Questions View all
Charge port melted now wont charge
Started to smoke and melt while charging. Now when I plug in charger it doesn't show it is charging on the power button. Assume it isn't charging but haven't run battery all the way out yet.
Add a comment
1 Answer
Chosen Solution
@smu89 if it truly melted you are having some major issues with it. Unlikely that it would charge nor would I try. Disassemble it by using this guide and see what damage you find. Post some images with your question so we can see what you see . Use this guide for that. Best case scenario you require only a new charging port, worst case you have some logicboard component failure.
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Very easy
2 - 5 minutes
Jawbone Big Jambox Charge Port Image
Guide
Jawbone Big Jambox Charge Port Replacement
Difficulty:
Moderate
20 - 30 minutes
Score 1
Add a comment
Add your answer
Jeff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 734
