Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
Easy fit speaker connectors
My Philips hts3544 receiver recently started going haywire and switching to mode after mode but the speakers worked fine. Is it possible to use the speakers from it on a different receiver that doesn't use the easy fit connectors by removing them from the speaker ends? Or will this just ruin the speakers? Any help is appreciated.
Add a comment
1 Answer
Most Helpful Answer
Yes you can, as the speakers are analog. You should be able to cut the connectors off and use them on any amp or receiver. However, the current receiver may apply digital affects to make them sound better, so using them on a new receiver might not sound as good. That may not be true, though.
Hope this helps!
Score 1
Add a comment
Add your answer
Ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 773
