Repair guides and support for the third-generation 5D, a DSLR camera released by Canon in 2012.
18 Questions View all
Replacing Mode Dial on Canon 5DMkIII
The button and metal face plate for the mode dial on my Canon 5DMkIII are missing. I lost them last December while running through the jungle, trying to keep up with a troop of chimpanzees. The dial itself is still intact and I've been able to change the mode by pressing a small pin into the button hole to unlock the dial.
I have a complete replacement dial/button/face plate in hand. Does anyone know how complicated it is to change this out or where I might find detailed instructions. . . . . .or at this point, should I just send it in to a professional for repairs (I have replaced components on a number of other cameras, with good success).
Thanks!
Score 1
3 Comments:
my canon 5d mark 3 brokened hot sho. if i no how can replese that
by
Hi Robert
I have this same problem with my 5dmkiii. Were you able to figure it out on your own?
by
Hi anyone found a place where they repair this issue?
by
Add a comment
If you have the mode dial cover you can replace it with a little lock tight super glue if it came with the 3m adhesive on the back it will fall off again. I had this same problem. Also you will find a small notch on the mode dial that helps you to align it properly. I hope this helps.
Add a comment
Bonjour
Voici la solution:
https://www.amazon.fr/vhbw-rechange-rota...
Je l'ai commandé et reçu.
La rondelle se colle avec un auto collant qui est fourni par le vendeur.
Bernard
rousseaubernard93@gmail.com
Add a comment
Add your answer
Robert Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 40
All Time: 2,895
