The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
86 Questions View all
How do I remove the lower radiator hose?
I am replacing my radiator in my 2001 VW Jetta and cant get the lower radiator hose off. I pulled the clip off but am not sure how to pull off the hose with out braking it since its all plastic.
Add a comment
Most Helpful Answer
See if this video points you in the right direction.
https://www.youtube.com/watch?v=3ShCTe8Y...
Score 1
Add a comment
How do I remove parts to get to the radiator upper hoes and lower horse
Update (02/25/2018)
I went under the car and took the fan off i took off the lower hoes off but I can’t take off the upper hoes because of the clamp it’s facing up and I can get to the teeth to open it
Update (02/25/2018)
It’s the hoes from the under vw Jetta 2005
1 Comment:
Buy some LONG pliers "BFPs". Don't worry - Harbor Freight is cheap, & you'll use them all the time.
by
Add a comment
Add your answer
Greg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 3,512
