Released April 2015. Identified as model S070Q.
21 Questions View all
Why does my phone go to optimizing apps when it comes on?
My phone sometimes goes off when the battery is below 10% and when i put it back on. it goes to Android is Starting, optimizing apps 1 of 125. i don't know what to do, it does this all the time, and because sometimes the battery is already low it'll go off again and continue where it left off. After the phone comes on, it'll stay for a few minutes, maybe five and go off again and start that whole process all over... I really need some help to solve this issue. I t would happen once a week but now its happening all the time. is it something i delete or uninstall? or install? Help Please!!!!!!!!
Score 2
Add a comment
Most Helpful Answer
If you have it installed, Zedge is causing this.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
Score 4
3 Comments:
Omjesus, thank you...
by
Yup my phone was doing the same thing uninstalled zedge app and it stopped thank you
by
Thank you immensely. That was it.
by
Add a comment
When you say the phone goes off again after you have turned it back on, is that battery still low? If it is, this might point to a fault with the battery, there's not enough charge in it so when it says optimizing apps, its turning off as there's not enough power to keep it on. Try with your charger plugged in. If it doesn't cut off with the charger connected I'd say that's a pretty good chance the battery is faulty.
Score 1
Add a comment
Hi.. Everyone's saying delete Zedge or trueCaller but I have none of them apps.. Can someone tell me a different way other than rebooting my phone
Score 1
Add a comment
Why my phone everything I open it.its goes optimizing app 1 of 1?
Add a comment
Idk but if anyone has any ideas please post because I was told Zedge but I don't have zedge
Add a comment
My power button will, all of sudden not work. So I tried to keep it charged so I wouldn't have to turn on, without power button working. Twice its lost battery but turns right back on, to “optimizing 1 of 1
Anyone have power button issue.
And I erased hedge, but is still doing it.
Add a comment
Add your answer
Kishma Lewis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 8,599
