Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Washed out screen after screen replacement
I have an iPhone 5C that was brought in because of white vertical lines on the screen. After swapping the screen, the new screen looks 'washed out', like it can't produce enough black.
Only the top ( about 0,5 cm) shows the normal colors with decent black. But all the rest of the screen is 'washed out'. I tried 2 more other screens: the second one same issue as the first one. And the third one ( other brand) is the other way around: that one is too dark...
Anyone got an idea? The original screen still shows the white lines.
Also tried another battery, but that didn't help.
Thanks
Update (07/22/2017)
I also notice the icons were visible when booting(??). And when booted, if I went to another page, I could see a shadow remain of the icon of the previous page. Very strange.
Update (07/26/2017)
I received 2 new screens yesterday and both screens showed problems again. The supplier said it could be related to a defect to the backlight controller.
However the device is still in warranty for 3 weeks, so we'll try warranty first.
But it's probably not related to the displays. 5 bad screens seems very unlikely.
Add a comment
1 Answer
Chosen Solution
I would posit that be that because each screen (at least from different suppliers/brand) has a different set of symptoms, you most likely have a bunch of bad screens. You need to use a known-good screen in this case to eliminate any logic board issues. I would also believe that if the issue was with the LCD driver circuit, you would see consistent failure symptoms across all screens.
Score 1
1 Comment:
Thank you for your reply. I guess it's a possibility, but what are the odds that 3 different screens are defective? With the suppliers I use I sometimes have a faulty replacement. I'll see what the supplier answers and maybe order another new one.
by
Add a comment
Add your answer
FD Tech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 5,071
