This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
173 Questions View all
My front camera failed after water damage
A few days ago i dropped my Samsung J7 in to water for about 30 seconds , its just a short amount of time . after that my front camera always " warning : Camera failed " until now . what should i do ? How to fix it ?
1 Comment
Suddenly my front camera stopped working ,and its a techno droid pad 7c pro
by
Add a comment
1 Answer
Chosen Solution
Maddi Lynch that "its just a short amount of time" does not matter. You will have to treat the water damage first. You cannot properly diagnose the failure until this is resolved.
First do not turn on your phone, charge it or try to connect it in any way. Remove the battery as soon as possible from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points are still pertinent to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Adding images to an existing question for that.
Once it is properly cleaned, replace the battery and reassemble your phone. then you can properly troubleshoot. It is entirely possible that your problem is caused by a short circuit in the camera module, but it is also possible that it is a board component for your camera that has shorted out.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 1
Add a comment
Add your answer
Maddi Lynch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 48
All Time: 9,642
