The Explorer saw significant exterior, interior, and suspension updates for the 1995 model year, losing all its exterior bodywork shared with the Ford Ranger.
27 Questions View all
cant find my overdrive fuse
overdrive fuse
where would I find my overdrive fuse on my 2001 ford explorer
Update (07/29/2017)
Overdrive off switch, sub woofer and compass display not working and the automatic door locks not working either by themselves when I put in gear. the engine size is 4.0 it is a v6 Eddie Bauer special OH yeah the reverse lights are also not working the book I have says they are all on the same circuit I don't know what is wrong someone said it might be a fuse for overdrive or something like that
Score 1
Add a comment
Chosen Solution
@elmyragulch check fuse #9 and#10 and see what they look like. A lot will depend on which engine size your Explorer is. The other information you should consider giving us is why you are looking for the fuse.
Update (07/29/2017)
@elmyragulch thank you for clarifying what is going on with your vehicle. Looks like most of your issues all tie into fuse #27 so I would start there.
Update (07/29/2017)
@elmyragulch here are the wiring diagrams for all of your vehicles circuits 2000 Ford Explorer Wiring Diagrams
Score 4
10 Comments:
that fuse is good . do you know where I can get a more detailed veiw of my wiring diagram and where exactly all the fuses are meaning under the ones under the hood or anything else that may solve the problem I have a book but i cant tell from that it is a haynes repair manual for ford explorers 1991 thru 2001 cant afford another book right now i have checked all the fuses i can find also checked all wires for any kind of damage even went back under the car to re check tranny since it was recently changed i have only had the truck 1 month so i dont know if the problem was there and just didnt notice my husband is the one who swapped out the tranny because we woke up one morning and it wouldnt go into drive that was 1 week ago other than the above mentioned problems it drives like a dream passed smog with fling colors please help
by
Let me see what I can find
by
thank you so much
by
mine is 2001 are they the same
by
yes they are identical
by
Show 5 more comments
Add a comment
With as many problems your experiencing I would use a multi meter in the panel and test all the fuses . If you are not sure on what to do set your meter to omh with sound and start on one side of the panel and touch each of the probes to the top of the fuse . Go until you don't have a tone on the fuse then pull that fuse and replace. If your OD continues to blow the fuse you may want to pull the shifter shaft to see if the wires in the column are broke. This is a common problem in the fords with the button on the end of the shifter lever . Hope this helps
Score 2
Add a comment
Add your answer
TINA SCHWARTZMANN will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 14,593
