Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2273 Questions View all
How do you fix the iPhone 7 ghost touch issue after screen replacement
After replacing a screen for iPhone 7, I countered an issue that the screen has a ghost touch then I tried to check whether the connector is good, clean the connector and reconnect it, everything seem ok but the ghost touch issue is still exist.
Any suggestions? Plz help me, thank you.
Score 6
5 Comments
I have an Iphone 7 with similar issues. Everytime I would play a game, certain presses made other areas of the touch screen to be pushed! I tried everything, from switching screens , even thought about swirching digitzers. I finslly FIXED IT with the use of ELECTRICAL tape. I put electrical tape on both sides of the Iphone after Opening it , making sure that no metal parts were visible, and IT WORKED! the ghosting issues are Nonexstent. Its most likely that a loose screw fell under the motherboard causing an electrical shortage, .
by
hello Choyy Mengg can i know how to put the tape on the both side of the iphone
by
I had this problem for like 5 days where my touchscreen would just press on random things that I wasn’t pressing and it was unresponsive. But it got fixed out of nowhere. One day it randomly stopped doing it and it hasn't happened ever since.
by
@Amir Zand And how is that helpful?
by
"Makabu-ang ni nga problema". This is what I did and I already shared it to my Manager to confirm if it still works on his iPhone unit.
1.) If your affected iPhone unit has with tempered glass already then please remove it.
2.) Clean the touchscreen from any printed marks.
3.) Temporarily attach clear scotch tape on your iPhone's whole touchscreen. It's okay if it overlaps each other because this is just to test.
4.) Perform testing.
5.) If you think your problem is gone then remove all the scotch tape, clean then find plastic type screen protector then let expert guy to attach it onto your touchscreen.
6.) Much better if you attach first the plastic type screen protector then cover it with the glass tempered. Maybe by this you'll know also what's the cause of this specific annoying problem of iPhone units. Worst case also is defective LCD or touchscreen.
That's all for now and maybe it helps to solve your problem.
To God be the Glory.., all the time!
by
Add a comment
Chosen Solution
Hello Kaye,
Defective display assembly, flex cable or pin damage and improper seating can all be causes of ghost touching.
Temporarily hook your display to the logic board and power on your phone without seating the display within the housing; simply hold the display up above the phone while connected and see if you experience ghost touching. If not, then the cause is likely from improper seating - maybe a cable is being pinched or the metal backplate on the LCD is touching a component in the phone where it shouldn't. Even look for a loose screw that may be lodged somewhere in the phone. Also check to see if the EM shield that covers the proximity/front camera flex cable is in the correct orientation.
I have found when replacing the iPhone 7 display that the metal backplate doesn't always like to sit flush around where the cables. Reassemble the display into the phone making sure everything fits properly.
Hopefully your replacement part is good and there is no connector damage. Likely, something is misaligned and causing an electrical short that disrupts the digitizer.
Score 8
1 Comment:
Have you tried this one? https://goo[.]gl/DMwFho
by
Add a comment
Most Helpful Answer
After checking with Chinese phone repair shops, which has large volume of business and a lot of experience on the subject matter, these are what they found.
iPhone 7 screens are more sensitive to individual variances and screens made by different suppliers like LG,Toshiba, Sharp have different sensitivity, in the factory the phones are calibrated on the line so there is no problem. However depending on how you've swapped the screens, you may encounter ghost touch or insensitive screen.
On the backlight plate, assuming the screen is not a Chinese workshop remanufactured unit that Frankenstein parts together,
Toshiba screens have manufacturing code beginning with C11 or F7C,
LGs have DTP or C3F,
Sharps have DKH or C0N,
Crossing between Toshiba and Sharp gives you about 5% chances of bad touch, while crossing LG into or out of the equation has around 50% chances of ending you with bad touch because LG sensitivity range distribution is very different from Toshiba or Sharp. Without the official Apple calibration magic box, it is very likely to not work properly if your phone is built with LG screen but reinstalled a different one, or the other way around.
So that magic calibration box has its value after all, unlike Louis Rossmann said it is just there to !#^& 3rd party workshops off.
Score 15
9 Comments:
the best answer ever tested 100% correct I do LCD refurbishing I did 4 different LCDS i.e. LG was the worst LCD despite it is original ! I wonder how did you get those code ? please share more info because when I read the QR code I get no results but I get the first 2-3 digits or numbers match with what have you posted here and I identify the BAND manufacturer please add more info as I have more codes that you did not add
Regards.
by
this is GREAT info, thank you for sharing. I can confirm I have ghosting going from LG to Toshiba. not immediately but after using the unit for 5 minutes.
by
Does anyone know who makes "FVQ" displays? They're the most common that I've seen and commonly have issues when switching manufacturers
by
im wondering about FVQ displays as well if anyone has info about them, greatly be appreciated
by
100% true man. Your info greatly help me to reduce complaint from my customer. Basically every phone originally come with LG screen is a pain in the ass. Since most of original screen available around in my country is either Toshiba or Sharp.
The remedy (at least for now) for LG calibrated phone is to use "non original" screen instead. Weird i know, but it turns out that AA screen has lesser chance of touch problem when it comes to LG calibrated phone.
by
Show 4 more comments
Add a comment
Hi,
This could be a few issues.
The main culprit might be cable damage, you may have accidentally pinched the cables when closing it up.
Or, it could be screen quality, if it's a copy screen, these can have issues, or might be a faulty screen, try get a replacement.
If a replacement doesn't fix it, then you'll need to look at possible logic board damage, connector may have been damaged, or something knocked off.
Definitely try a new screen though. :-)
Score 3
Add a comment
Hello All,
I have run a small repair business for 7 years now. I pride myself on quality work, so when I began to have about a 20% return rate for phantom touch issues I knew I had to dig my heals in to try and figure this out.
First thing first - I do not use OEM displays. All my displays however are high quality copy with TIANMA LCD’s and I have used the same supplier and same quality level for years without issues.
I’ve come up with the following procedures during iphone 7/8 repairs and have not had a single return since. I’ve also done these procedures on returned units with the same display and fixed the issue.
First - the Metal rectangular cover on the flex cable of the new screen has to be positioned perfectly. The best way to determine the position is to take a pair of calipers and measure from the frame of the phone to the edge of the loudspeaker. For example, the Iphone 7 measures 30.50mm and the iphone 7+ measures 44.50mm. I use a piece of kapton tape to hold the flex cables in place, measure from the edge of the screen to the edge of the cover, adjust, measure etc. Once you have it where you want it, install the metal backplate. If you make the actual position of the edge of the rectangular cover match this distance within +0.2mm/-0mm you’ve completed step 1.
Second - I’ve noticed that on the original displays, the rectangular chip cover is one solid piece covering all the critical components on the flex. The chips installed on the aftermarket units are wider then original, and they have made these fit under the cover by cutting the edge of the cover leaving the chip exposed. If yours are the same as described, cover this exposed chip with a piece of Yellow Kapton tape.
Third - When installing the screen back onto the phone, install all 4 screws in the flex cable cover loosely. Side the metal cover upwards as far as you can with all 4 screws loose. When you have it as far upwards towards the top of the phone as you can, tighten the 4 screws.
I’ve got photos of all the critical steps if anyone would like a copy, send me a message,
Score 3
24 Comments:
Hi that is really good information.
I like to learn about these faults and like to see the step by step pictures.
Please sent.
Thanks in advance.
Mervin_binda@hotmail.com
by
hi.. please send me photos step pictures..
thankz
pinheiroemelo@gmail.com
by
Hello,
I have a similar issue. I would appreciate the pictures and detailed explanation. Please send to london.technologies@gmail.com
by
Photos and additinal info accepted, please tmi.carlsson@gmail.com
by
Can u also send it to me?
Emrekaratas@Live.nl
by
Show 19 more comments
Add a comment
over the years, I did have a few ghost type issues after screen replacement with after market screens on iphone 7 that is. It turned out that the only solution worked for me is to replace the screen. I do believe that when the after market screen is matching to the OEM screen, that is when the problem is going away. So you would have to match the lg to lg or toshiba to toshiba etc… It is a rare problem, but it does happen and then you should pay attention.
Score 1
Add a comment
I think you should try the following.
I had a customer with the exact same issue and I placed a screenprotector on it and it stopped.
I don't know if this is for everyone, but I think it's worth the try. Just buy a cheap screenprotector and check if it solves the issue.
So again I can't confirm it works all the time, but if you're out of options, give it a try.
Add a comment
I myself read many answers to fix my phone ( iPhone 6). It use to “ghost type” and freeze.
I read in some forum to twist the phone. Which gave me the idea that screen is not in straight line. I removed the screen guard and cleaned the iPhone screen. It did not work.
Finally, I removed the hard case that it had to protect back. All the problems were immediately gone. It seems the hard case itself got twisted by a previous drop which was further twisting iPhone screen.
1 Comment:
I have exactly the same problem started soon after I replaced the screen myself. The screen works perfectly when I remove the hard back case yet there is no visible dent or imperfection on it. How did you resolve the problem, if you solved it at all? Thanks
by
Add a comment
Anyone have an answear about FVQ reference ?
2 Comments:
FVQ manufacturer is currently the biggest question know to man it seems. absolutely no one knows , could it be samsung?
by
FVQ is Toshiba.
by
Add a comment
Try this out…i read some comments to place screen protector on screen,
before I buy screen protector,i put clear plastic to my screen to prove it and boooooomm,it worked,the ghost is gone.and i buy screen protector,,problem solved.
Add a comment
I had also this problem with my two iPhone 5s after two weeks from screen replacement. "Makabu-ang ni nga problema" because it even automatically deletes texts when you're typing for messages. Let me share this with you of what I did.
1.) Removed my existing screen protector and cleaned the touchscreen.
2.) Temporarily attached clear scotch tape on my iPhone's screen. Overlapping is ok for testing.
3.) Performed testing and problem is gone.
4.)Removed clear scotch tape and replaced with new screen protector [tempered glass].
That's all and maybe it helps a little to solve your problem.
Add a comment
Add your answer
Kaye will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 52
All Time: 101,398
