Can I replace my power supply with a atx power supply?
I am doing a custom design for my Xbox one, need to know if I can successfully do this.
i litterally did this this evening, my brothers xbox one brick died, and im a pc guy, so i just gave the xbox 12v and 5v, and it was golden.
just put a switch on the green wire on the 24pin motherboard wire to any ground, and the power supply will turn on.
the brick has the required voltages labled clearly, and ignore the power on (usually blue) and the rsense wires in the xbox power brick.
Easiest mod ever. The PSU is simply 3 pin 12VDC power and 3 pin GND. Just look at the pinout from the board shot and you can figure out which is which.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,474
1 Comment
I want to find out the same too, It should be possible once the power supple have a spec exact or similar to the xbox one power US original adapter which is +12V 17,9A. Once you can find that on a ATX and the right wiring it should power on.
by Full Bring
