Released in 2006, identified by model number PP20L for e1505
16 Questions View all
Good source for a Express card 16GB SSD under $30
My laptop has bad overheating issues at the HDD because it's constantly running at Max load. I need a 16 GB expresscard SSD which would be just enough for Ubuntu. Does anyone know of a good source for a SSD under $30? I'll never use my expresscard slot anyway, so this may put it to use. It's a 54/34mm slot. Or an adapter solution. Thank you.
@danj @mayer Anyone?
1 Comment
Anyone? Anyone?
by
Add a comment
Chosen Solution
@pccheese - George, I doubt you'll find one for so little. How about a micro-drive like this: IBM 1GB Micro-drive
Score 2
2 Comments:
Alright, thanks. Do you know if I can use my wireless card slot for an SSD?
by
I doubt it as the needed driver may not load
by
Add a comment
I found the reason my HDD was overheating. In the BIOS, there is an HDD option for quiet, performance, and bypass. I suspect the performance mode forces more voltage that this cheaper HDD can't handle, and overheats. I put this settings on bypass and now the HDD stays much cooler.
Score 1
Add a comment
Add your answer
George A. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 334
