The HP Pavilion x360 15-bk020wm is a 15.6" laptop with a touchscreen. With Windows 10 operating system, Intel Core i5-6200U Processor, 8GB Memory, and 1TB 5400rpm Hard Drive.
9 Questions View all
Why is my laptop not able to charge?
I can't recharge the battery in my laptop.
Add a comment
There could be a couple of problems to check. First your charger might be broken, or the part that plugs into the computer could be broken or bent. The part in the computer that connects the charger could be broken or dirty. And the battery could be dead or close to it which you would need to replace it. The cable connecting the batter to the laptop could be loose. Also after the computer is fully charged it should be unplugged because you could be over charging the battery.
1 Comment:
"Also after the computer is fully charged it should be unplugged because you could be over charging the battery."
This is a mith
Having a battery fully charged and the laptop plugged in is not harmful, because as soon as the charge level reaches 100% the battery stops receiving charging energy and this energy is bypassed directly to the power supply system of the laptop.
by
Add a comment
Is the laptop not getting power or is it getting power but not charging the battery?
Add a comment
  1. The power went off while I was using my laptop while plugged in with the battery removed a after then it didn't a accept power again
Add a comment
Add your answer
Meshayla Block will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 576
