The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
28 Questions View all
when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
Score 2
2 Comments
I am putting new battery in car . When i connect horn goes off won't
by
Check if you are connecting the correct battery terminals.
by
Add a comment
Chosen Solution
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
Score 2
1 Comment:
What if you don't have a key fob
by
Add a comment
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
Score 2
2 Comments:
Even when I get the car running thorn keeps beeping! Now what?
by
Start the car, put in reverse, drive and shut off the engine.
by
Add a comment
Add your answer
TWB will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 72
All Time: 26,647
