Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
67 Questions View all
Sudden shut down and not able to switch it on
I was using my oneplus 3 and it randomly shut off. It wont respond to anything. Battery charged 90% enough for 10hrs . Tried pressing power button and volume down buttons same time, for factory reset it wont respond. I faced no such issue earlier. Everything was fine till now. Please advise.
Score 3
2 Comments
Wait till next day for the battery to drain completely .then charge again.
by
I kept my phone in fridge for 20-25 min. then tried to plug in to dash charger n started pressing on/ off button several times and tried plugging unplugging cable while pressing on/off button n mobile got switched on
by
Add a comment
Most Helpful Answer
Mine does this. The way to fix it is press the ON button while plugging it it and keep it held down while you unplug it and then plug it back in again. That always fixes mine. Don't ask me what causes it to shut down in the first place though.
Score 7
7 Comments:
OMG this really worked for me! I have no idea why, but it does!
I only registered for this website to say thank you and confirm this solution :)
by
Worked for me too. No idea how does it work. And yes I also signed up to say thanks :)
by
How its work anyone tell me.
by
I just signed up to thank you! You saved me a lot of trouble! I am eternally grateful to you!
by
Can confirm this works on a 3T as well. I don't know how you figured this out, but THANK YOU!
by
Show 2 more comments
Add a comment
I am using one plus 3 phone but it often switched off automatically . And when I gng to switch on some times it's not respond and some days 10-15 days working good and some days daily 10-15 times is going on switched off pls anyone give suggestions wat I will
Score 1
Add a comment
Have you tried the unbrick guide from the OnePlus forum? It may be a software issue, and if so then the first method in the unbrick guide should solve it. :)
https://forums.oneplus.com/threads/guide...
Add a comment
Add your answer
POTHUMUDIS will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 50
All Time: 10,934
