Repair guides and support for cars and other vehicles produced by the Chrysler division of the Fiat Chrysler Automobiles US LLC.
194 Questions View all
Where is the cabin air filter in a 2008 Chrysler Town and Country?
I can't find the cabin (A/C) filter in my 2008 Chrysler Town and Country. I've looked in the most common places like behind the glove box, under the hood, etc. If someone knows exactly where it is and how to get to it for this year and model, please post the answer.
Score 5
1 Comment
I have a Chrysler 2007 town and country with the same problem. If somebody know how to replace it , please let me know.
by
Add a comment
Chosen Solution
I could't find cabin air filter of town country 2008 also and I for sure this model don't have cabin air filter, look on manual book page 449 " A/C Air Filter - If equipped " with my understand on Town Country some model have cabin air filter.
Score 1
3 Comments:
That is correct, some do and some don't. If you can't find it in the location as suggested by the manual, it probably doesn't have one.
by
I really wanted to know about a 2009
by
Hi I bought a 2009 T&C and it has no filter behind the glove box just a vent for cold and hot air to go into the Minivan. Canadian Tire did sell me a Fram filter that fits the 2009 that do have it and the number is FRAM CF10743.
by
Add a comment
Most Helpful Answer
The only place that I could find is :
Vehicle: 2008 Chrysler Town & Country Touring 3.8 V6 GAS
The cabin air filter should be replaced every 12,000 miles.
  • Open the glove compartment door.
  • Push inward on both sides of the glove compartment, then lower the glove compartment door.
  • Carefully pivot the glove compartment downward.
  • Through the glove compartment opening, disengage the cabin air filter access door retainers from the HVAC housing, then remove the cover,
  • Through the access door opening, remove the filter element,
  • Carefully install the new cabin air filter element into position
and more
You were on the right track, it is behind the glove box.
Here are the instructions from the manual.
1. Remove the lower glove box bin from the instrument panel
2. Disengage the two retaining tabs (1) that secure the particulate air filter cover (2) to the passenger side of the HVAC air distribution housing (3) and remove the cover.
This is the cover behind the glove box that needs to be opened.
Just to update my answer. Your vehicle will have to be equipped with this optional filter. You wont find it if it is not one of your options. I now attached page 421 of the manual to verify my previous answer. Good Luck
Hope this helps
Score 3
3 Comments:
I looked around for cabin filter 2008 dodge caravan Canadian tire mechanic said it is dirty, I followed to check under the glove box but there is no cabin filter slot.
by
2009 T&C some or all may not have a filter at all mine does not
by
@steveroe29280 that is correct and was addressed in the original answer as well "Your vehicle will have to be equipped with this optional filter. You wont find it if it is not one of your options. "
by
Add a comment
Here's how to do it: http://www.ehow.com/how_4506455_replace-...
Score 1
Add a comment
Granted, this is pretty old, but my 2008 T/C Limited 4.0L engine does have one behind the glove box. With the glove box opened, behind it is a black horizontal plastic plate with a tab on the left and right sides. It comes out with no effort. Behind this plate is the filter which slides out toward you. Mine is very dirty and I was just looking for the correct size to look up.
-Munch
1 Comment:
it does not have one at all so you save your save like me 32 bucks for a good filter
by
Add a comment
My van don't have one
Add a comment
Add your answer
aks12 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 145
All Time: 36,319
