checking iPhone with multimeter
Hello , i am trying to find short to ground on iPhone logic board , what is the best way to check for short ? right now i put my multi meter in continuity mode and red probe to ground and black probe to the components .
Add a comment
1 Answer
Chosen Solution
What device are you testing?
Your approach is fine...for continuity, it doesn't matter whether the red or black probe is on ground. By convention, it should be the black probe. To find the component that is actually causing the short is a bit more difficult. Any component on the shorted line will also appear shorted. You have to use any visual clues (damaged or corroded components) or intuition (which part of the phone is not working or if the entire phone, where is there the most damage).
Finding a short on a main voltage rail like PP_VCC_MAIN is more difficult as there are dozens and dozens of components which could cause this. Ultimately, you may just have to start pulling components one by one. There are more advanced tricks like injecting voltage and looking for overheated parts (using freeze spray) as well.
Give us more details about which device you are looking at and what the problem is and we can give you more directed help.
Score 1
Add a comment
Add your answer
Jamil Yousafi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,017
