The next-generation 2007 Santa Fe debuted at the 2006 North American International Auto Show in Detroit.
20 Questions View all
My at transmission stuck on 4th gear and not change
i have a hyundai sant fe 2010 i have change my engine 24 after changing it in workshop my at transmission start to stuck on 4th gear not chancing at all i tried a lot of solutions but no thing happen
solution have been tried:
1-tithing the battery cabels
2-changing the oil of the transmission
3- software to the transmission of the car by obd2 scan and reader code device
note(when i get my car to a obd2 scanner it shows that one of the selonide are not working and when repeat the scan it gives onther selonide not working and the first which is shows in the first scanning work good in this scan and move on in every scan one work the other not after change in the other scan
Score 1
Add a comment
1 Answer
Hello,
I had same issue with santa fe 2010 3.5 and whole gear box changed and it costs too much.If you have this problem that is when you should consider why always me
Add a comment
Add your answer
abdaladem alwan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,667
