LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Questions View all
poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
Score 2
2 Comments
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
by
Hello
I have the same problem, did you find a solution?
by
Add a comment
Most Helpful Answer
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
Score 1
1 Comment:
8 minutes ago by Gabriele Filoni
by
Add a comment
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
Score 1
1 Comment:
Thank you very much it works!
by
Add a comment
Add your answer
Gabriele Filoni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,121
