Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
255 Questions View all
Possible causes in vertical lines of LCD
A few days ago I tried to increase the memory of two iMac's, from 8GB to 16GB, using memory with factory specifications.
In the first everything turned out as expected, however, in the second, after making the change, the LCD screen showed two vertical lines since the system started. I replaced the original memories and the problem persists, have I damaged any components?
Which component could have been damaged? Thank you very much for your comments and suggestions.
Actualización (24/08/17)
This is how look
1 Comment
@joepep post some pictures of what your display shows with your question. That way we can see what you see. Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
@joepep - Jose I've got some bad news here ;-{ When you tried opening your system without using the correct tools and technique you damaged the LCD displays fragile wiring. Sadly, this is not repairable. You'll need to replace it with a new screen: iMac 21.5" Display LCD Assembly, Late 2012 / Late 2013
Here is the proper IFIXIT guide to follow: iMac Intel 21.5" EMC 2638 Display Replacement
And the needed tools:
And you'll need at least one set of adhesive strips: iMac Intel 21.5" (2012-2017) Adhesive Strips
Plastic Cards Image
Product
Plastic Cards
$2.99
iFixit Opening Picks (Set of 6) Image
Product
iMac Opening Wheel Image
Product
iMac Opening Wheel
$7.99
Score 1
Add a comment
Add your answer
Jose Neftali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 651
