Repair information for the Crusher Wireless headphones. Model number: S6CRW-K591. First available on Amazon in August of 2016.
24 Questions View all
Bass lever not working
Not be confused these are NOT the original crusher headphones.
The bass lever on the left ear cup is not working. I tried taking it apart to look at the circuit board but everything looks perfect from the inside.
Add a comment
1 Answer
I had this problem when I first got my pair as well. First of all, make sure the headphones are charged and that you are using the charger that came with the headphones if you are charging it for the first time. Then to fix the problem hold the power button (left side above slider) and the volume up button (top-right) at the same time for about 10 seconds, this will shut down the headphones completely without the voice saying “power off”. Then turn them back on and while listening to something, start moving the bass slider up and down and it should work again after a couple seconds
Add a comment
Add your answer
warrenspottedeagle will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 66
All Time: 1,256
