Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
202 Questions View all
Reading PS1 disks fine but refuses to play PS2 games
Alright I have been working on a PS2 that I managed to rescue from being used for parts on Ebay, it had been stripped down and sold for not working but I found out that the issue was a broken fan connector which took minutes to fix. I have since reassembled it and its been working fine with older titles like PS1 games, I do have to use a AV cable for them to load since using a composite video cable just gives a disk read error, I would test it with a SCART cable but I don't have one around.
Add a comment
Chosen Solution
Hi!
Could be the lens in the optical drive going bad.
Try wiping it with some alcohol and Q-tips, if it does not work you should replace the laser assembly.
PlayStation 2 Image
Guide
PlayStation 2 Optical Disc Drive Lens Cleaning
Difficulty:
Easy
15 - 40 minutes
PlayStation 2 Optical Disc Drive Laser Assembly Image
Guide
PlayStation 2 Optical Disc Drive Laser Assembly Replacement
Difficulty:
Moderate
20 minutes
Score 2
Add a comment
Do not use alcohol on dvd/cd laser lenses
Add a comment
Add your answer
1337KILLERZ will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 16
All Time: 696
