Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
iPhone Water Damage Repair Help
The iPhone 6s Plus I have has water damage and won't turn on at all.
When charging it, the motherboard does not get hot at all almost like it's not receiving a charge.
It does not respond to iTunes or is recognized at all.
I took all shields off and used 99.9% IPA already.
I have realigned the power management chip of the bottom right side of the back of the board. (It was crooked).
However, a small little chip or capacitor has fallen off in the process (see pictures). How can I reattach this chip? Also which other chips could be responsible for the death of my iPhone with no heat at all?
Thank you for helping out!
Add a comment
Chosen Solution
Well shooting for the Tristar is usually a good go to. Have you tested vcc_main?
Score 3
3 Comments:
I am fairly new to microsoldering so I'm not sure what vcc_main is. Could you clarify?
Also, the small little chip in the first picture is not important?
by
Nevermind, I have found vcc_main and the tristar chip. Will check them out. Thanks.
My only question that remains is what is the purpose of the small chip I knocked off in the first picture?
by
Blurry picture but it looks like a coil not a chip. Re tin the pads and replace it
by
Add a comment
@smarticles, it is FLDIP_RF, it is a signal filter and yes, important to have micro soldered back on.
Score 3
Add a comment
Add your answer
Diego A will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 193
