Can I add an SD card to this phone
How can I add more storage to this phone? Can I add an SD card?
Most phones will come with an SD slot, you will find this by the battery next to your sim card youll see "SD" or its logo.
before dissasembling check the outside rims as soem phones have a slot on the outside
Pick the size you want:
This phone in particular has the SD card slot hidden inside of the sim card tray or the volume buttons on the right hand side of the device. Once you open it, pull the tray all the way out and you will see the slot for the External SD.
I don't think this phone is equipped to take an SD card. yes, there is a tray that you can access by pulling out both buttons, volume up and volume down. however, this tray is for SIM card only. not the micro SD. the phone has either 32 or 64gb of storage so I assume they assumed that it was enough. hope this helps.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 23
All Time: 2,915
