A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
79 Questions View all
The washer keeps going threw cycles without stoping . c
I had it calibrated twice now and it now will not spin out all water. Then states sucking out water while lid is open . It would never even work without lid being lock before this. Please help
Score 1
1 Comment
I unplugged my washer for about 1 hour, and plugged it back in, and it went through it's cycles normal again..
by
Add a comment
Chosen Solution
Start here:
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Score 1
Add a comment
I unplugged my washer for an hour, and then plugged it back in and in ran it's cycles normal again... Idk why it was necessary but it reset it somehow,..good luck...
Add a comment
Add your answer
Rebecca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 775
