Why is my r2 button not working
My r2 button wont work right I have to press it really hard in Battle feild wont work in gta5 .
Dont know of this helps or not but…. If your controllers get dropped regularly, like mine do…..take it apart, carefully clean the contacts of the conductive film and it's respective contacts on the circuit board. I use 90%+ isopropyl alcohol and a few Q-tips. Scrub, but carefully. Then use a clean cloth to buff the film contacts and the board contacts. Make sure everything aligns correctly when you screw the circuit board back down. Screw the circuit board back down and connect the battery and try it out. Unless your controller is physically broken, or the rubber pads are torn or crushed, this should fix your problem. Unless it was submerged in fluids, just smashed to !&&*, or a button was physically broken from being to rough….this had fixed every single one I've come across with a “shoulder buttons worked and now they don't “ scenario. It's almost always that film. It moves and that was a design flaw.
Do you have any tips for the R2 activating when you're not pressing the trigger?
Could be a number of issues: the plunger on the inside of the button could be cracked, the button switch could be loose, or there could be dirt or damage to the button switch. Gonna have to open it up and have a look.
Here’s a simple solution to fix buttons that don’t seem to be working. It does requiring taking the controller apart.
Dude I logged in just to say thanks lol this link helped me big time. Just managed to fix my controller
How do i fix my r2 button to shoot without pulling it apart
Blow air into it with ur mouth worked for me
Did not worked for me lol ear me out if there is another solution to repair it whitout pulling it apart
Coby Roberds that actually worked, thank you
Past 24 Hours: 37
Past 7 Days: 215
Past 30 Days: 1,156
All Time: 153,562
2 Comments
Chk the rubber on L buttons if ok!.
May need some control setting on call of duty. Shooting button response fast/slow
Hope this answer fix your prob.
by adnan
I recently brought this PS4 controller on Amazon and now it’s not working on R2.
by Trever
