My machine is stuck on spin cycle
The machine turns on. It screen says spin cycle and then won't progress to spin.
It won't change to any other cycle.
I have tried holding on/off button on for 3 secs. as stated in error code and turning on/off at wall.
Score 1
Add a comment
1 Answer
Chosen Solution
Please give us your exact model number.
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 2
5 Comments:
How can express that my FRONT LOAD washer won't stop spinning, NOT ASKING TOP LOAD
by
no one addresses the stuck on spinning, why
by
as requested whirlpool duet mod awa9500aw03
by
@via13439
Please verify the model number of the washer as awa9500aw03 shows no results?
by
That lady wasn’t all that nice. We can all use a little more patience with each other in life. Mostly anyway.
by
Add a comment
Add your answer
Jeanie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 35,613
