Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1300 Questions View all
Is Tristar IC 1610A3 interchangeable with 610A3B?
Nice and easy question, Is 1610A3 interchangeable with 610A3B?
If it is, is it also interchangeable with 1610A1 (like it is with 1610A2 and 1610A3)
Score 1
Add a comment
Chosen Solution
The 1610AX are all cross-compatible although it's preferable to use an A3 in place of the older 1610A2 & 1610A1. As for the 610A3B, it can also be used wherever an 1610AX was installed. I would not use an 1610AX in place of the 610A3B in an iPhone 7 though ( I haven't tried it personally but some have reported is does work).
Score 4
3 Comments:
hello guys
i have tried a2 on iphone 7 plus and it work 100%
by
I just tried a A3 on a IP7 and had no joy , tbh i did just dive in and change out tristar after a new port and battery didn't work and pp_bat and vcc_main read normal, will investigate more tomorrow.
by
I just replaced 610AB3 with a 1610A3 Works fine.This is on Ipad Pro 10.5".
by
Add a comment
Can I use 610A3B for iphone 8?
Score 1
1 Comment:
sao diferente
by
Add a comment
http://wiki.level3.repair/index.php?titl...
Score 1
Add a comment
tou com ipad a1584, nao carrega, e ci dele e ci610a3c, sera que o ci610a3b e compativel
Add a comment
Add your answer
Jacob Harvey will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 32
All Time: 6,790
