Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
67 Questions View all
one plus 3t camera bezel fell out, no damage on the lens.
so i dropped my oneplus 3t hard on the floor while it was in a spigen neo-hybrid case. a few moments later i noticed a missing camera bezel and exposed camer. lucky for me, i found the bezel with the lens still attached to it. i then proceeded to cover my camer a with paper to prevent damage to the stabilizer till i can get a viable solution. pease try to answer asap
Update (09/16/2017)
images attched here. sorry for poor quality as my camera is a 8mp
Update (09/16/2017)
Update (09/16/2017)
i contacted the customer care as i was still in warranty and they claim it is accidental damage , and not a manafacturing defect, typical oneplus , they charge a hefty 6500inr to replace the backdoor which is metal and will take a week. so it seems my lens will neversettle (tm). now i scraped the plastic still left on the steel bits of the bezel and will proceed to stick it with with feviquick after cleaning the lens and bezel lens with isoproply alcohol. im sourcing the materials required for the cleaning part, will update status soon as i seem to be getting no answers :(
Score 2
Add a comment
1 Answer
Chosen Solution
I wouldn't use super-glue if I were you, as it might eat away the lens cover (super-glue is corrosive) or even damage the camera module. Use a more gentle adhesive. If you manage to stick it back in there, your problem should be solved if there is no other damage to the phone.
The fancy solution is to get a new camera lens cover entirely, those ship with the adhesive. Installing it is VERY simple... I've attached some links.
Cover 1, Cover 2
Score 3
2 Comments:
i completely agree with you , but the links you attached are only the lens, the part below the lens known as the bezel has come out which is only available if you buy the whole metal frame , so i was lucky i found my bezel. my problem was solved anyway, i used araldite in very small amounts which is a non corrosive glue. i will write a solution and guide sometime soon to help any others facing the same issue
by
Alright, glad you could figure it out yourself. looking forward to reading that guide.
by
Add a comment
Add your answer
neal kaul will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 586
