Kenmore is a popular appliance brand commonly sold by Sears, but Sears does not manufacture any of the appliances themselves. Instead, they source that out and have other manufacturers make their appliances for them. Kenmore refrigerators are made by a variety of different manufacturers including LG, Electrolux, GE, and Whirlpool.
138 Questions View all
Freezer and Fridge not cooling but fan is working
The fridge and freezer are not cooling at all. However the fan in the freezer is turning. Using a kill-a-watt, I can see that the fridge is using 60 watt (without the light). Which (I believe) is much lower than it should if the compressor would be working. Using a flat screw driver, I turn the defrost timer out of its cycle it will go to 2 watt and then back to its 60 watt. If I set the cooling knob to 0, it shut's off to zero watt.
I just moved in this house and this is a fridge that wasn't plug for 6 months. But it was working before the owner said. The make is kenmore but the model number is erased. It's a top freezer, probably from ~2005 ish years.
3 Comments
Update: The compressor is decently hot and the current seems to be reaching the compressor using a non-contact voltage tester.
by
my freezer is cooling slowly and before was warm why?
by
For future reference, a non-contact voltage tester is ok for some things. But this isn't one of them. It shows voltage is getting to the unit. Is it the right amount of voltage? It can't say. It also can't tell you if your start components have failed. Or if the compressor is seized and pulling Lock Rotor Amps (LRA). Or if it is thermally out. You need a multimeter to check these things. If you have to diagnose something like this, you want to first check if the compressor is pulling any amperage. Put the clamp around the black wire and see what it says. If it is reading at or a bit below the Run Load Amps (RLA), then move on to other things. If reading zero, time to find out why. Use a good cap checking meter to read the start capacitor. Average multimeters can't read that high, but a decent meter for this is $20. If the cap is reading nothing, or lower than the value on the label, it's bad. Replace it. If good, move on. Check continuity through the start relay. Is it closed? There are different types of relays, so I can't say what pin numbers apply to any given unit. But on the compressor there is Common (c), Run (r), and Start (s). 3 pins. The wire from the start pin should have continuity through the relay to the start cap. If it doesn't, it's bad and needs replaced. If it does, keep going. Time to check the compressor. Ohm between s and c, then r and c, and then s and r. S and r should read close to the other two readings combined. If it says OL from c to s or r, might be thermalled out, you'll have to wait for it to cool down. If it isn't hot and it shows OL, bad compressor. If s to r shows OL, bad winding in compressor. Needs replaced. That should get people a ways into diagnosing.
by
Add a comment
Chosen Solution
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Cause 2
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 3
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Score 2
2 Comments:
Thanks for the reply,
1) The condenser coils were pretty clean, but I clean them a little extra to be sure
2) I do not have a condenser fan since the coils are along the back.
3) The evaporator Fan works well.
Would you have other hints?
Thank you,
by
My fridge is sear 14yr old only work when I bump up temperature
by
Add a comment
All refrigerators have condenser coils and a condenser fan. Those are the coils below your appliance near the compressor. Your freon must go through those coils first before going up through your evaporator coils. The condenser fan makes sure that the freon going through your condenser coils stays cold once it gets up to the evaporator coils. If your condenser coils are dirty then that can hinder your freon staying cool.
So I would suggest to pull your refrigerator out and inspect the condenser coils and fan to make sure they are clean and working correctly.
5 Comments:
I just replaced my evaporator fan motor since it stopped spinning. It now spins… after 4 hours my fridge still want getting cold, would there be another reason besides the fan not working? My coils are clean… and the fan in the back is working great. . I can feel the cold air blow out very slightly into the fridge but it’s just still isn’t getting cold enough. Maybe the seals?
by
@cherrylcarver
What is the make and model number of the refrigerator?
by
Kitchen aid. Kbfa20ersso1
by
Waiting for answer
by
@rontatrai
Be patient. This is a worldwide forum and people who do answer questions are all volunteers with families, jobs etc and not everyone is in the same time zone.
Is the problem with your refrigerator that the compressor is not operating?
If so click on the + 3 Comments link above the Chosen Solution and then check out the 3rd comment posted.
Moderator.
by
Add a comment
Add your answer
Alexandre Lacoste will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 68
Past 30 Days: 349
All Time: 33,352
