The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
LCD and Screen replacement
I removed the gold strip next to the battery above the home button flex when removing the LCD digitizer after front glass removal. Can I continue with the repair or is it now repairable?
1 Comment
You should upload a picture of it then others can help you.
by
Add a comment
1 Answer
Chosen Solution
The best way to find out is to test the new screen and see if it's responsive. I'm not entirely sure if it's just a heat dissipation piece or part of the sensor for the touch screen.
I know the back of the new LCD should have the film attached as well, so I can only assume that it's a heat dissipation piece.
Score 1
Add a comment
Add your answer
Lainey Yancyfjgbmp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 150
