format / hard reset my tablet
Hi all , I have gone through the hard reset up to clicking on the factory reset but then I get a quick flash of green robot on his back with a red triangle , then it goes back to logo with no option for yes or no to confirm reset .... Please help me !!!!!!
Add a comment
Chosen Solution
Hi Carl,
I'm not sure which way you are using to factory reset your tablet but the steps I provide should help with factory resetting it successfully:
- Turn Off your Samsung Galaxy Note 10.1 device.
- Wait for 10 seconds, Then move to the next step.
- Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
- Wait for it to be fully on and then you can start using it.
1 Comment:
Hi Nita , thanks for your help , but the problem I am having is still there as when I get to the wipe / format the tablet , I click on it but instead of going to the yes / no option , I get a flash of a green robot lying on its back with a red triangle on top of it , and instead of yes / no the tablet goes to the loading icon and reboots automatically back to where I started ........ Please can anybody help ....... Many Thanks to Nita for your help so far ........
by
Add a comment
Thanks for your help , but the problem I am having is still there as when I get to the wipe / format the tablet , I click on it but instead of going to the yes / no option , I get a flash of a green robot lying on its back with a red triangle on top of it , and instead of yes / no the tablet goes to the loading icon and reboots automatically back to where I started ........ Please can anybody help ....... Many Thanks to Nita for your help so far ........
1 Comment:
How weird! Make sure you're clicking the correct buttons or maybe having it plugged in while you do this will help. Otherwise I'm not sure what the problem could be!
by
Add a comment
Add your answer
Carl Egan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 47
All Time: 333
