Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Lawnmower problem with Fuel pump
I have a lawnmower that gets veey little gas coming out of fuel line. I have replaced fuel filter,pump, and lines. Now I discover the line coming from crank case is blowing air instead of a vacuum voming through line. What could be causing this and how could I fix it
Score 1
Add a comment
1 Answer
Most Helpful Answer
Check line from valve cover for cracks and leaks. Set valve lash. Plus check compression on that side cylinder. Mine developed rust scarring on one side, blew smoke. Am re-ringing with oversize and bore. One thing that helped for a little while was running a gravity feed fuel cell on top of hood.
Score 1
Add a comment
Add your answer
Tony Coleman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 236
