Internal display problems after repair
After I replaced a faulty right speaker in my MacBook Pro 15" Mid-2014, the internal display went awry. The screen is distorted, visually squeezed to the left-third, is fuzzy like static in an old TV.
What works:
External displays work. Both HDMI and DisplayPort. All other functions, like airport, keyboard backlight, FaceTime video, and all work.
What I tried:
- I've reset PRam, SMC. Tried safe mode and recovery.
- Cleaned any dust/dirt away from connectors with dry, soft toothbrush
One of the steps says be very careful not to touch the cable connector after removing it. Could it be that I did, and this is the result? I've tried reseating it several times and I see no change. Do I need to clean it, with what?
Images:
Login page. Internal display glitched. Functioning external display (in mirror mode) above laptop.
The display connector looks clean. What's a cheap/easy way to clean it more?
4 Comments
Has anyone even seen this pattern before? Certainly vertical lines... but the compressed image too?
by slshepard
I have a replacement screen on the way to see if the problem is solved with a new display...
by slshepard
Finally got my screen after a shipping snafu. The problem shows on the new screen as well, so it’s something in the main board or female main board display connector.
by slshepard
Were you ever able to solve the problem? The chosen answer seems inconclusive. It's 2024 and I replaced the battery in my 2014 MBP. After I put it back together, I'm running into the same exact issue as shown in your photo – most of the screen output is smashed into the first 20% of the screen with vertical lines equally spaced. I'm able to connect to an external display ok. I suspect maybe the socket connector on the motherboard for the display cable is somehow damaged. To have the exact display anomaly as you had seems strange. At 10 years old, it might be time to retire the machine. It's a shame though... it has a brand new battery 🙂.
by netvector
