The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 Questions View all
When I turn in there is a screen asking for a code. How to enter code?
The screen shows some ok ok line and at the bottom there is firld for 'Code'.
What is code!
Add a comment
1 Answer
Most Helpful Answer
@mkh12 I've checked the manuals and I can not see anything that would require you to enter a code. The only code that this camera might show is a fault code. I would suggest that you remove the battery to reset your camera and see what you get. You did not tell us when this code comes up. if ti does so right at start-up or somewhere in the menu. Try to reset your camera by following these steps.
Score 1
2 Comments:
When I turn on the canera there is a screen on top of the menu options showing the few things:
State: Idle
LogDir: HS00
HsCmd: ok
Hsnet: ok
HTTPc: ok
Code :
What are these?
How tonget rid of this window and goto normal mode?
Is it busted?
Please let me know.
by
that sounds like a diagnostics menu. Let me check the service menu later for. this is a DMC-TZ5?
by
Add a comment
Add your answer
Md Kamrul Hasan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 79
