Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
54 Questions View all
AF-P 18-55 lens autofocus issue
The lens suddenly stopped auto focusing. What may be the issue ? The camera is autofocusing with other lens but not this one. I have tried to clean it and re attach it but the problem persists.
Score 3
Add a comment
There seems to be an issue in the lens, since you have said you had other lenses that work (assuming they are also AF-P). Could see if the connectors are working correctly and are clean (check the camera’s as well).
Does the manual focus work at all? The AF-P lenses use a fly-by-wire system for the manual focusing, so if that does work, then it is likely the camera and/or lens has manual focus set, and the lens is communicationg to and from the camera, and the focus motor is working.
Add a comment
Same problem with my D5500 as well. It do not auto-focus
Score -1
Add a comment
Add your answer
prabhuti samal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,227
