How to add freon
how to add freon to a 1990 Red Dot R9720-1
Add a comment
Chosen Solution
You can't buy it anymore. It's illegal in the USA
From 2015, it will be illegal to use Hydrochlorofluorocarbons (HCFCs), including the ozone-depleting refrigerant gas R22, in refrigeration, heat pump and air conditioning (AC) systems. R22 is commonly used in AC systems pre-dating 2004 and so its ban will have a major effect on air-conditioning costs.
All new air conditioners and heat pumps use R-410A, the more “environmentally sound” refrigerant. R-22 is still the most commonly used refrigerant in existing air conditioning equipment in residential homes today. However, per the Montreal Protocol, caps have been established to eliminate the production of R-22.
Score 3
4 Comments:
Here’s an alternative for R22 DuPont M099 you can use in the US.
by
@mayer - Re-use is allowed. Here’s one outfit H3R Clean Agents. You are correct production & sale on virgin product has ceased.
Halon used in computer data centers as a fire suppressant system is likewise no longer produced but you can recycle it! Boy did one of my accounts make a killing reselling it when they decommissioned one of their data centers.
by
The price of R22 has gone thru the roof. Today R-22 can be as much as $50 per pound. Typical residential air conditioning units hold from 5 to 15 pounds of R-22. If a coil has to be replaced or there is a leak the cost of refilling the refrigerant could be $250 to $750.
As for Freon, I could not find a price. But, without a license, it is illegal to even buy it. Only a licensed specialist can buy it or install it.
by
Did you take note on the cost of Halon? It’s even more expensive and you need at the minimum 30 pounds for a small unit.
Yes, R22 is expensive! As some units can’t use the newer stuff they have you over a barrel! Some can take M099 product which is clean and you can get at Chemours
by
Add a comment
Often when you need to recharge a cooling system you have a leak in the lines or condenser coils. Do a full inspection of the lines using a marker within the coolant (refrigerant) and black light to locate the leak. Once you have resolved the leak/s then you can recharge the system.
Depending on your country you maybe limited on what refrigerant you can use. Make sure you comply with local govement regulations. As far as recharging you’ll need a gage set and you may need a compressor as well. Lastly, a tank of refrigerant and you may need a second empty tank to remove the old refrigerant to fix the lines.
Here is a copy of the Red Dot Service Training Manual: Service Training Manual
As there are so many versions of the unit it’s best to contact Red Dot directly to get the needed manual and details on what refrigerant you can use for your exact unit. Here is their contact page: Red Dot Corp.
Score 1
Add a comment
Add your answer
Lawrence Swenor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 653
