The DigiLand DL1010Q was released late 2014 in Europe. The device uses an Android 5.1 Operating System.
25 Questions View all
How can I get the inverted colors to turn off?
I have a DL1010Q Digiland tablet. I replaced the lcd screen and now the colors are inverted and I have not found a solution to take the inverted colors off. Everything else works on it. The touchscreen works and I can get into all apps but the colors are inverted.
Score 1
Add a comment
1 Answer
If it looks something like this...
https://forums.androidcentral.com/attach...
...then it's either a loose/damaged/misaligned/not-fully-connected LCD signal cable, or a bad connector on the LCD or on the motherboard. I've also seen this effect happen if the signal cable is inserted the wrong way (e.g., the LCD end into the motherboard and the motherboard end into the LCD).
If the colors are ACTUALLY inverted there's a setting. Ggo to the app drawer and go to the Settings menu. Find Accessibility and open it. Enable Color Inversion. Once you have enabled that option, go back to the home screen. Pull down the notification drawer and open Quick Settings menu. There is a new button which will invert the screen if tapped.
Add a comment
Add your answer
Maria will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,511
