The Sony Playstation 2 SCPH-790xx is the fourth revision of the Playstation2 slimline model.
12 Questions View all
Correct cable for SCPH-79003 power/reset?
I need to replace the cable and I've been looking for one online....
Will this cable work when trimmed down to 8pin? : http://amzn.to/2xK7EVU
I bought this one from eBay which works but turned out being too short in length : http://ebay.eu/2hC1z9G
thanks for any help.
Score 1
2 Comments
@tonictinsk what is the exact model number for your PS2?
by
Add a comment
1 Answer
Chosen Solution
@tonictinsk apparently there are a few version of the cable out there. This one is the long version for the SCPH-79001 version which will also work with the European SCPH-79003 version.
It is possible that the first cable would work if you trim it, but I'd be careful with that since you do not know if any wires are crossing etc You will need to know the spacing between the wires to fit your connector. You can of course always try it out and let us know if it worked. You'd only be out a few £
Score 1
2 Comments:
@oldturkey03 can confirm first cable works after trimming it down! very relieved as it required a lot of patience. The cable is quite long aswell so had to tape it down.
Here's a few photos: https://photos.app.goo.gl/SxDlUo1pmuQHFM...
by
@tonictinsk excellent! Glad to you've tried it.
by
Add a comment
Add your answer
Anthony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 312
