Laptop is not starting
Hi
Ma laptop not starting . When i press power botton laptop fan started but no display on screen
A lock light blining continiously till 20 time
Hi
Hi,
Here is a link to the service manual for your laptop.
Click on the Diagnostics link in the page to find what the LED error codes indicate.
If for example it is the middle LED that is flashing this indicates a Memory compatibility error
Check the following:
1. Install compatible memory modules.
2. If two modules are installed, remove one and test. Try the other module in the same slot and test. Test the other slot with both modules.
3. Replace the memory.
4. Replace the system board.
Hopefully this is of some help
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 800
2 Comments
Is it possible to opperate my Dell E5410 laptop with out a battery, but pluged in to AC with the cord?
by Rudy Rempel
@rudyrempel Yes.
by mike
